Veritas - Innovation in Tools
a little carving-very little turning
I have a beam ceiling in my house. The genius's that built it notched the 4x10 to put another 4x10 into it. So basically I have just a 4x4 supporting the juncture between the guest room and hallway. Not a good idea. It is the main beam supporting this juncture. I have glued up 2 2x10's to basically give me a 3x 9 1/2. I'm carving some oak leaves into it sort of like you would a mantle. I will bolt it to the other beam with 6 lag bolts and probably some glue. I will fill the lag bolt holes with turned buttons (see I said it had turnings). I'll probably stain the leaves and leave the rest natural. It's on a beam that starts up the stairs so it should look pretty good and hopefully make that joint a little stronger.
Re: a little carving-very little turning
David Walser
John -- Your laminated beam would be a lot stronger if you sandwiched some half-inch (or even quarter-inch) plywood between the 2x10s. It might not be as attractive, but it would provide better structural support for your roof.
Dick Coers
Lags aren't good for carrying load. Through bolts are preferred.
You couldn't have picked a worse wood for carving.
Keith Newton
The alternating hard and soft annual rings make it hard to control the chisels. You should always try to get something with a more uniform consistency. DAHIKT
Re: You couldn't have picked a worse wood for carv
It's challenging my skills. I just couldn't find thick wood that large around here other wise I would have picked something else.
