inside out rings
This is just a series of tests to play with inside out turning on platters. I have way too much work to do around the house to be turning but you know, I have to have my fix so I do some cuts, glue up, then run outside and mow or work on the new sidewalk or other things. I was able to turn these 3 ornaments playing with inside out platter techniques. Just wanted to see what the problems are so I can work them out before stepping up to larger pieces and more expensive wood. I was using my cheap blade for the segments and it shows in the Cherry. When I got to the Oak ring I switched to a good blade. You can easily see the difference in the accuracy of the cuts and glue ups.
