Why display w axis vertical?
Charlie Belsen
With multi axis turning, sometimes none of the axis are, in the finished piece, vertical (square to the surface on which the piece is displayed). This can cause the asymmetric piece to lean, sometimes adding implied movement to the piece, sometimes just hinting that something is just not normal.
That got me wondering. Many turnings are not intended to be functional but rather as wood sculpture. Once the need for functionality is removed, why can a flat spot be created just of the 'normal' bottom, allowing the piece to be displayed 'leaning'?
Re: Why display w axis vertical?
Depends on how far it can lean.....
JamieDonaldson
,......before it falls over! ;)
The leaning tower of Pizza..
i have done this many times.
Keith Newton
I usually carve 3-4 feet on most of my hollow form pieces. Sometimes I tip a grouping over, like three singers using one mic. This however is disturbing to non creative people. It is not unusual for them to come along and stand them up in a line.
