Ruined MT
Ruined MT
Ruined MT
Dale Gillaspy
In a moment of complete stupidity, I drilled into my MT on the headstock of my Powermatic. I had a large twist bit in my tailstock drilling into hard wood. My intent was to drill all the way through and then stop. I must not have felt the difference between the wood and metal and drilled into the MT about 3/4 of an inch. Not that it really matters why, but I had the radio on in the shop and the news had just broken into the report about the Orlando mass shooting.
Anyway....I'm assuming this part is replaceable, and labor intensive, I'm sure, but for those of you who have a machinist background, is that the best option, or should I go to a machine shop and have a new MT put into it. I know it would make it sit farther back in the spindle, but I don't think that would affect anything....help???
Thanks,
Re: Ruined MT
Re: Ruined MT
Dick Coers
Shouldn't be that tough to replace. I don't see a way to put a new taper in there short of boring it out more, pressing in a sleeve, and reaming in a new taper. Replacement shaft will be cheaper. You could shorten the shaft some, losing some threads, but then getting closer to the taper that is left in there. But I don't like that idea much either. I hardly ever use the morse taper on my Oneway. If I have a chuck on it and want to use a drive spur, I have a spur designed to fit in the chuck.
Re: Ruined MT
Re: Ruined MT
I agree, replace the spindle. It would be just as labor intensive to remove the spindle for machining as it would for replacement AND if machined, the new full taper would sit too deep in the spindle.
I use the MT a lot, both for a variety of drive centers, jacob's chucks, rubber chucky mandrels, pen mandrel, custom mounts, and my favorite, holding long, thin spindles (far better than a chuck - I cut the taper into the end of the blank).
Unless you accidentally drilled very deep most existing mandrels and things will still fit but probably not securely enough to suit me.
In a pinch you could probably get by for a while by filling the drilled section with JB Weld then reaming to size. You can buy an MT2 reamer for $25 but it would have to be reamed with precision which might be difficult holding the reamer with the tailstock on the wood lathe.
Re: Ruined MT
Re: Ruined MT
Dave Paine
Wow, that is a big "oops". You have my sympathy. I would be kicking myself.
The taper is part of the spindle which is the part you would need to replace. As you said costly in time and materials.
The headstock diagram from a Powermatic 3520B from the manual. The spindle is part No 4.
A full length MT2 taper is 2.25in. I do not know if manufacturers of wood lathes make full length tapers. If yours is full length, you may get away with using the short taper with your MT2 accessories, although you may need to use a drawbar.
I think attempting to get a bushing to press fit into the 3/4in hole will not be easy since I expect the diameter of the hole may not be consistent. On my metal lathe a drilled hole is not consistent. I have to bore out or use a reamer to get a consistent dimension. It will not be easy to get the taper in a bushing to align exactly with the existing MT2 taper. If not aligned well, then MT2 accessories will not hold.
Perhaps an easier solution is to get a machinist to make an adapter to screw onto the spindle threads with MT2 taper.
What are the MT2 accessories you presently use? Can they be replaced with versions which use a chuck or a collet chuck?
Re: Ruined MT
Re: Ruined MT
david delo
Not as a permanent fix but is there enough meat left in the taper that you could tighten up your center with a 1/4-20 drawbar?
Re: Ruined MT
Re: Ruined MT
Dale Gillaspy
Yeah, I usually use a Steb style drive for between center work and I have one that will fit in my chuck jaws...just hate that I did this and I like my tools to be complete and working right, not just getting me by.
Re: Ruined MT
Replaced spindle.
Doug Wolf
Dale, We had to replace our clubs 3520A spindle shaft in 2010 due to demonstrators messing up the outside (1-1/4') threads and here is the result.
We took the headstock to a local Powermatic approved dealer repair shop and it has been like new ever since. The prices have probably gone up since then. Good luck.
Re: Ruined MT
Re: Replaced spindle.
Wow! Looks like something I would do. And kick my self in the butt for it. I would rant and rave and kick myself for days. OTOH, I have what is practically a motto, any blunder that can be fixed for less than $100 is not worthy of that much outrage. Been saying something like that for thirty years, so maybe it should be $200 when adjusted for inflation. I would replace the shaft. Especially if I could get one for the price mentioned above. I am concerned this weaken the shaft and the tapers would never work right or be safe. And I want my machines to be "proper" and not kluged together and require odd fitments to keep going.
Re: Ruined MT
Dale Gillaspy
Yeah, I agree. I think I'll just bite the bullet and look into a new spindle.
Re: Ruined MT
William Duffield
The spindle, part # 3530B-204 is $124.33 from Powermatic or $133.68 from ereplacementparts.com.
https://parts.powermatic.com/SearchResults.aspx?s=3520b&PageNum=3
http://www.ereplacementparts.com/powermatic-3520b-1352001-tefc-2hp-220v-woodturning-lathe-parts-c-32549_32637_32638.html
Re: Ruined MT
Doug Ladendorf
I don't know how old your machine is but you may want to replace the bearings while you are at it. It's relatively cheap insurance.
Re: Ruined MT
Dale Gillaspy
Good point.
Re: Ruined MT
And if your careful removing the bearings you will have them as back ups in case the new ones ever go bad.
Re: Ruined MT
Re: Bearings are likely generic
Dave Paine
Good idea to consider replacing the bearings if you decide to replace the spindle.
The bearings may be purchased from a bearing supply house.
For example in the 3520B manual they should front bearings (Qty = 2) as code
BB-6207ZZ
The bearing generic code is 6207ZZ. Dimensions and specifications are defined by "6207". Shield material is defined by "ZZ" which means two steel shields. May be stainless but depends on manufacturer.
The rear bearing is BB-6206BB. Dimensions and specifications defined by "6206". Shield material is defined by "VV" which means two non-contact shields. May be Viton or some other plastic depending on manufacturer.
The bearings will state the manufacturer. If you purchase the code and same manufacturer it will be the same as purchasing from Powermatic.
Re: Ruined MT
Joe Kaufman
Received Chinese manufactured spindle bearings from Powermatic about a year ago. Did not like the grinding quality of the external surfaces so purchased NSK bearings made in Japan. The original bearings were made in Taiwan and look as good as the NSK.
Re: Ruined MT
Doug Ladendorf
Agree. Japanese bearings are not terribly expensive and are good, consistent quality. Another brand I have used for several projects is Nachi.
Doug
