TBC for pens
TBC for pens
TBC for pens
eliot feldman
I recently purchased a Wall Street II pen making kit and see that the ends of the blank are to be turned to 0.474 inch diameter and that the drill size is 27/64'', which is on the large side. So the usual set up requires two identical .474 bushings on the correct mandrel, etc.
I don't have these bushings.But I have a good verniers caliper. And I can't see any reason in the world not to just do it between centers. For that, supposedly, you need four additional tools: two little bushing-like inserts at each end of the blank, one 60 degree dead center cone at the head stock , and one 60 degree live center cone at the tail stock.
Naturally, I have the live center cone, but not the other three. And now I don't see any reason in the world not to make one wooden bushing-like insert for the tail stock end and a wooden morse taper insert with the same size tenon to fit into the head stock spindle for the head stock end .Then I would turn it between centers.
That's what I am going to do. I don't see the need for all this stuff!
Re: TBC for pens
As long as time is not an issue
Dick Coers
As long as you don't mind the time it takes to turn your accessories to eliminate the parts you would purchase, you are correct. On the other hand, order $5 of bushings when you buy the kit, and the pen is done before you could get your wood parts made. It's always a trade off. We can do with a lot less tools for all our turning. But where's the fun in that? LOL
Re: TBC for pens
Even More Fun....
jake niedling
There is even more fun after you buy it and that is finding it again when you need it. :)
Re: TBC for pens
Re: TBC for pens
Do you have a mandrel? I've made bushings and a set of "finishing cones" from HDPE, nylon should work, etc.
I drill for a slimline tube, glue the tube into the piece of plastic, then turn what I need. The plastic is less likely than some materials to get glued to the end of the pen blank if finishing with CA.
Re: TBC for pens
Re: As long as time is not an issue
eliot feldman
Well, I don't really turn pens to have still another pen, which I will probably give to somebody anyway. I just get a kick out of turning them. I believe what I like best is the opportunity to use numerous exotic woods at modest cost. So I rather enjoy the process more than having the final object.
Re: TBC for pens
eliot feldman
Oh, and I forgot:turning them between centers is actually a superior method in that, without a mandrel, the work piece is shorter and turns truer with less vibration. And using a good caliper is more accurate than relying on a bushing. Just my two cents.
