Accurate drilling into odd shaped pieces
Craig Daymon
I'm working on a mirror that will look like a flower with the mirror in the center. It is a mirror meant to be sat on a table/dresser.
The stem is mahogany and about half of a offset-turned doughnut I made a while ago, with a flat sanded on the thicker end to attach to the base. There is a 1/2" tenon at the back of the bloom to attach it to the stem, but I need to accurately and securely hold the stem so that I can drill the hole (without destroying the stem).
I'm looking for any suggestions as to the best way to proceed. I have a 17" drill press and, of course, the lathe as drilling options, and assorted hand-held drills. Was planning on using 1/2" Forstner bit, but maybe that is a bad choice as well?
Thanks in advance.
Oh, the base is Curly Maple dyed green. The blossom is Camphor Burl with a Masur Birch 3" center (same size as mirror) and there is a Kingwood half sphere on the back where the bloom portion of the tenon is glued into.
A bearing from an old hard drive is epoxied into the center of the blossom behind the mirror and also epoxied into the Kingwood knob. Base, stem and knob will be fixed (logically) and the bloom will be able to spin, though probably shouldn't exceed 5400 RPM. :-) Those bearings are incredibly smooth and quiet.
I'll try to remember to post pictures.
