Richard Raffan Finish
Sharon in Topanga
Wayne and I won a Richard Raffan demo piece at the Utah symposium. As it is unfinished, we would like to finish it, preferably using materials he would have used. Does anyone know what finish he uses?
TIA
Sharon in Topanga
TIA
Re: Richard Raffan Finish
In his books, videos, and demo he talks about and shows an oil and wax finish but I didn't see where he gives the recipe. On this page he mentiones beeswax.
http://www.richardraffan.com/node/102
There are several finishes made from oil and beeswax, usually heated and mixed. If you pick one it would probably be very close.
Dave Paine
If Richard uses a finish with oil and beeswax, he may include one of the U-Beaut products, since this is an Australian company.
UBeaut EEE Ultra-Shine friction polish is beeswax, something to keep this as a creme consistency and tripoli for the polishing.
David Walser
In his early videos (so early they were on VHS), Raffan simply holds a piece of beeswax against the spinning wood until a little of the wax melts onto the wood. Then, he used a rag to melt/spread the wax over the surface of the wood evenly. Couldn't be simpler.
don stephan
In the lidded box dvd, he first applies an oil, wipes it dry and immediately applies the beeswax. If I remember correctly at different times he mentions linseed oil, walnut oil, and mineral oil - the latter may have meant to be linseed or walnut.
Re: Contact Richard Raffan
jake Niedling
I would just contact Richard directly and ask him. If you go to his webpage, you can find his contact information. Here is the link - http://www.richardraffan.com/contact
I would most likely just use a Kraylon spray clear matte finish or some microcrystalatine wax like Renaissance. Beewax is his main finish. I think unless you can spin it again, putting on a beeswax finish will be difficult.
Sharon in Topanga
FYI I contacted Richard per your suggestion. His response is he normally leaves these boxes unfinished. If I wish to finish it he suggested a paste wax or blo.
Thanks for your suggestion.
>>... unless you can spin it again, putting on a beeswax finish will be difficult.
You've got that right, Mr Jake!
I have applied beeswax after the fact by warming the wood with gentle heat from a heat gun then rubbing the wax on the wood (like a big crayon) melting with the heat gun. Spread and rub into the wood, reheating as needed.
I suspect the oil and beeswax "paste" finish some people use could be applied off the lathe ok. I have also just rubbed Renaissance wax into bare wood - I'd probably prefer that to bare wood.
