Re: Problem with Jet Mini Lathe
eliot feldman
I called Jet. They were as helpful as they could be ,but about all I got from them was that the hand wheel was probably loose and that I should try to tighten it -- and that it is a left-handed thread.
The problem, as I explained to them, is that the wheel won't budge. They didn't have too much to say about that except to use a monkey wrench and a towel to keep from dinging up the hand wheel. I didn't like that solution because I believed the polished wheel would become damaged even through the towel.
I tried drilling to free up possible burrs, but that didn't work. What I eventually did was to clamp on my largest wooden clamp -- the kind that has two all thread rods -- one normal and the other left-handed-- and try to turn the hand-wheel (counter clockwise) using this clamp. The clamp slipped some, but I think I may have moved it just a little bit.
My next attempt will be to find a couple of stout boards, hinge them at one end, wrap a rope at the other end around both boards and twist the rope with a large bar to tighten the boards around the wheel -- like using a nut cracker -- and then try turning the wheel that way. We'll see.
