They're also good for holding odd shapes
David Walser
A few years ago, the American Woodturner published a series of articles showing how to make a vacuum chuck that conformed to odd shapes, such as natural edged bowls. The chuck has a thick layer of rice (or similar medium) inside a plastic bag/donut. The turning is sandwiched in the chuck between the the rice and a compression ring. The edges of the plastic bag are extended outside of the compression ring, sealing on the inside of the ring against the turning. When the vacuum is turned on, it draws out the air from around the rice and sucks the compressing ring down onto the turning, holding it tightly in the chuck.
The combination of the having the rice conform to the shape of the turning and the normal holding power of a vacuum chuck, allows odd shapes to be held very securely. It's an interesting and flexible concept. The first article can be found in the June 2012 issue.
