I'm also trying to vizualize
Geoff Whaling
I'm also trying to vizualize - trying to think more about why you would want to do that (on a spindle blank)?
With a very small step rather than a tennon shoulder, it can be done with both long (toe) & short (heel) points, although the finish may be ordinary. Leading with the short point would produce a better finish.
It can also be done with the long point to a degree with a larger shoulder on a tenon to say take a small relieving Vee in the corner of the shoulder to take out fur that might bind in the dovetail jaws. I use the skew as a negative rake scraper to tidy / true up the tenon on dry face grain bowl blanks.
I think most things can be done with a tool edge if you have a good understanding of the mechanics / physics of the cut. If you understand the hazards of each tool & application it becomes a risk management exercise.
A matter of selecting which technique is the most successful in terms of producing a satisfactory product / result with minimal risk on injury.
Guilio Marcolongo does some very rapid end grain hollowing in hard Australian timbers with a skew to make his signature boxes, and he does exactly what you mention to produce a flat bottom inside the box - a skewed negative rake scraper.
