Home made beading tool
After watching Harvey Meyer do some basket illusion pieces I thought it might be fun to try and make a beading tool that works similar to the Dway. I took a 3/16" HSS steel cutting bit. I used a 1/8" green Dremel grinding wheel. I mounted the wheel in my metal lathe chuck and then fed the bit into it by mounting it in my tool rest. I fed it in a little and the raised the bit and fed it again. Took a while. that steel is hard. The grinding wheel overheated the bit but that won't hurt HSS.
Then I ground some mild relief on the both sides. I got the points too thin and they chipped off so I simply ground them round. Still seems to work as you can see by the test piece of dogwood behind it. YOU use this tool flute down and the points must be on the center line.
The beads came out pretty clean.
