Curious PM3520a behavior
Hal Taylor
A few weeks ago I turned on my PM 3520a by pulling on the power switch as I usually do. It was the first turning of the morning so I had just plugged up the lathe. Since it was a new piece I usually make sure the speed was turned to zero. Luckily, it was a fairly small spindle because the lathe sped up to (apparently) full speed before I hit the power button. Scratched my head, made sure of the settings and tried it again - same thing. I then looked at the read out on the VFD - it was not zero, maybe 128. I hit the reset button a number of times and it finally went back to zero. Everything worked fine then. Yesterday - same thing happened, but this time I had a fairly heavy piece I had been working the previous day. When the lathe sped up there was a loud pop from the piece before I could hit the power switch. Luckily the piece stayed on the lathe, as a big crack had developed. As with the previous experience I hit the reset button a number of times and the readout went back to zero. In both situations it was the beginning of the day after plugging up the lathe, so one would assume the VFD would have gone to "zero state" as well. Has anyone had or heard of this experience?
Maybe I should try "plugging in" instead... Or maybe when I plug it up is when the problem occurs...
