Chuck adaptors
Chuck adaptors
Chuck adaptors
john Lucas
When I first bought my Vicmarc chuck it came with a short adaptor but worked fine on my lathe. Then I bought a Powermatic. The Spindle is longer and this chuck didn't bottom out against the spindle face. I built a small metal ring to fit this space. When I bought a new Vicmarc chuck they had inserts that were longer and took care of this problem.
One of my newer off brand chucks also had this problem. The other off brand had the same short insert but worked fine on the lathe. The problem is the distance from the back of the chuck to the inside of the chuck. I put the chuck on my metal lathe and increased this depth so the chuck now works fine with the shorter insert.
I'm trying to decide whether to do that on the Vicmarc or just buy another long insert.
Re: Chuck adaptors
Re: Chuck adaptors *LINK*
Tom Gall
John, …. I just use these spacers (for shaper cutters) from Grizzly. Easier than making your own or re-machining your inserts. Reasonable price and come in several thicknesses, although the 1/4" is probably all you need. I also use the 1" i.d. sizes for spacers on my tool rest post. If you need/want any less than 1/4" thick you should be able to get them from MSC, Enco or McMaster-Carr.
Grizzly spacers
Re: Chuck adaptors
Interesting, someone might need these
It's easy enough for me to make my own, which I have done. It's just keeping track of it. So far I have always had a magnetic light on my headstock so I just stick it to that. However I have been thinking about moving that light so then I'd have to find an easy place to keep it. There should be a vicmarc dealer at the AAW symposium so I may just pick up the right size insert.
Re: Chuck adaptors
Not Vicmarc inserts?
Geoff Whaling
John, was the adaptor a standard Vicmarc insert? All of the standard Vicmarc chuck inserts that I have seen will cater for about 35-40 mm of spindle thread.
Nova / Teknatool chuck inserts were much shorter and suffered the issues you mention on most lathe spindles.
Unfortunately some manufacturers suffer a bad wrap when other manufacturers unbranded items are confused with the OEM's gear. We had issues here in Australia quite a few years back with some non OEM inserts having the two threads (inner & outter) apparently manufactured on different axes! Not good for run out!
Re: Chuck adaptors
Re: Not Vicmarc inserts?
Geoff pretty sure this is a vicmarc insert but it's very old, probably more than 15 years.
