Tormek wheel
john Lucas
I've been playing with my Tormek. When I grade the wheel to course it leaves almost the same finish as when it's fine. Maybe just slightly duller. It seems to roughly match the finish I get off of my strip sander using a 400 grit belt. I get a noticeably finer finish using my 800 grit sanding belt. I'm sanding Short HSS cutting bars to get a comparison.
I'm doing this because i don't feel the Tormek was leaving a fine enough finish on my carving tools before going to the leather strop. I would like to end up with a mirror finish and what i'm getting is a mirror like finish with fine lines in it which are the lines left by the wheel.
I'm leaning toward setting everything up on my strip sander to do my carving tools. However I like the jigs that you can get with the Tormek. I don't have any yet but have been drooling. However if it won't leave the finish I like then I'll have to set up a system with the strip sander.
