1000 grit CBN wheel
robo hippy
Well, I have to experiment. I recently got a 600 grit wheel from Ken Rizza, and the cutting edge results were significantly better on both gouges and scrapers. The scraper burr was excellent for shear scraping, but wasn't big enough or heavy duty enough for heavy roughing. Same with the gouges. Couldn't notice a lot of difference with the skew though. Well, again, my curiosity got the better of me, and I ordered an 8 inch 1000 grit from Ken, just because..... I have only had it out in the shop for an hour or so, but maybe there is hope for me and the skew chisel after all... Scraper burrs were about the same, both standard and negative rake. The skew, well it made a big difference, which probably means I never learned to sharpen one properly. I did find that I was getting different results going from left to right and from right to left on a piece of highly rippled sugar maple. I had not honed off the tiny burr. So, took the 600 grit CBN hone to it and the results switched. After several very light honings, there was no difference, and I was leaving a nice slick surface that before I was getting tear out that I could only tame with a 600 grit burr shear scrape, but I can cure just about anything with that. I still need a hundred or two hours of play time for any definite results, but that just makes every thing more fun. I will have it on my grinders down in Atlanta.
Now to see if I can find the second myrtle plank that is hidden in my shop. Turned most of the first one yesterday and today...
robo hippy
