ADVERTISE HERE - FREE TRIAL
turning a sphere by hand
Keith Tompkins
Keith Tompkins
One way to turn a sphere without a jig. Lay out a square block, find the centers, and draw a circle on two sides. Bandsaw the first circle, staying just outside the line, and don't cut all the way through. Then, cut the second circle, again, don't cut all the way through. Carefully remove the excess, the result should look like the bottom image. Then, draw a heavy pencil line on two sides, as shown, mount on the lathe, and turn until the pencil line is very thin. Revove the tenons with cup centers. To sand, mount a piece of scrap board on the lathe, and remove the center to match the diameter of the sphere. You now have a board with a big hole in it. Cut the result in half, and glue sandpaper to one half to use as a near perfectly round sanding guide.
Re: turning a sphere by hand
Dick Coers
Nice technique. I saw another one I like. Mount a platform under the stock, that has a circle drawn on it of the size sphere you want, above the bed of the lathe. Bring a strong direct light over the lathe. It will project a shadow onto the platform drawing. Remove wood until the shadow matches the circle drawn.
Bill Howatt
I've always done the few I've made by drawing a few lines on the rough cylinder and then cutting at an angle between them Even made a spreadsheet with the various measurements for different diameters.
This circle/bright light trick sounds very simple in comparison if it works well in practice. May give it a try.
Bill
Re: turning a sphere by hand *LINK*
David Walser
Brian Havens has a nice Youtube video that shows the shadow technique. He learned it from someone (whom he credits in his video for the idea). In his video, he uses the shadow technique to create a human silhouette. Like virtually all his videos, it's well worth your time.
The shadow technique
david delo
I've watched his shadow method a couple times and will probably try it in the future. Being on sort of a sphere making kick lately these recent threads have been of great interest to me. I make them with a early version of the Carter and also make them with the Berger Sphere Calipers. Does a nice job and once you do a few goes pretty quick start to finish.
https://www.youtube.com/watch?v=R4s5LziiS08
Tom Albrecht
Excellent video link, thanks. That shadow method seems so obvious now. I frequently have to make newel and post caps by eye. This idea will be a great help. No $$$ jig needed.
TA
Bill Howatt
He credits David Reed Smith who also published it in Woodturning Design magazine. Here is a link to Smith's very comprehensive list of helpful articles. I seem to recall his name on turning forum posts a while back but I can't recall which forum assuming it was the same person (probably was).
Bill
David Reed Smith Turning Articles
