ADVERTISE HERE - FREE TRIAL
Alisam index pin revisit
john Lucas
Here is the link from the AAW forum so you can get more info and also to give credit to Don Bunce who came up with the fantastic idea.
http://www.aawforum.org/vbforum/showthread.php?5834-Alisam-indexing-system/page2&highlight=Alisam+index+wheel
Re: Alisam index pin revisit
Thanks for this! I actually read this thread and saw the counting jig at the end but plum missed the pin design...
further refinement to index spring index pin
john Lucas
What I really need is a way to use the index that comes with my Vicmarc chucks. I modified Don Bunce's idea some more. The pin can be rotated 90 degrees so it fits in the back or the side indexing. When I turn natural edge bowls and few other items that need to be sanded with the lathe off, it has always been a pain finding a way to lock the lathe spindle in various positions to be able to sand efficiently. This solves that problem and is very quick to reposition.
I used a 3/16 piece of steel. ground the end to a point and then ground off the point until the end fit into the holes in the back of the chuck very snug. then i found it also works in the side as well. unfortunately the holes are different sizes in my off brand vicmarc copies so I would have to make another rod to fit those but it only takes a few minutes to make one.
Re: further refinement to index spring index pin
David Walser
This very cool. I spent some time on Vermec's website today. They have an indexing arm that works with Vicmarc and Nova chucks. Your innovation is a lot less expensive (but it doesn't give as many index options).
Vermec's is almost twice as expensive as the Alisa
