Nova 2024 Tool Slide
Jeff Rich
A couple of years ago I got a fantastic deal on a Nova DVR2024.
It was a return and there was "nothing wrong" with it other than the index pin being loose.
After I had it set up and turned a few items, I noticed that the toolslide would loosen up and move, even if repeatedly tightened.
I have contacted Nova with no luck AND no chance at warranty, because I bought it as a return. Unfortunately they have been less than helpful. This is NOT a slam or bash against Nova, I just want a fix to this frustrating problem.
As you can imagine how a loose banjo can affect a bowl coring.
I have tried flattening the bottom of the banjo, making sure the ways are level...
Have any of you found a fix for this issue?
In my photo the white arrow points to the bolt you need to tighten.
