Alisam spring loaded index pin.
john Lucas
I forgot who posted this idea on the springy index pin for the Alisam. What a fabulous idea. Whoever posted this get back with me because I want to give credit. I did modify it a little. I put slot in the bottom piece because I want to be able to use it on my midi lathe as well. I will make another spring for the midi and another bottom locking piece.
I did put screw threads on the bottom of the spring arm and fastened in place with a thumb screw on top and set screw to lock it in position. The idea is to be able to really fine tune the position of the wheel when I need to pull the turning off and reinstall it. This way I can lock the spring in the wheel, loosen the set screw and rotate the thumbwheel up or down and then lock it in position. My slot wasn't quite long enough for both lathes so I bent the arm out a little and that took care of the problem.
The extra hole in the side of the bottom piece is simply because this was a scrap piece of aluminum that already had that hole.
I'm going to make another spring to fit my IronfireLLC wheel so I can use either one with this system.
Re: Alisam spring loaded index pin.
David Walser
John -- A couple of questions: 1 - What size rod did you use for making the indexing pin? It looks like a very good fit. 2 - Where is the spring in the spring loaded index pin? I assume that it's the rod itself. Is that the case? (Okay, that's three questions.)
john Lucas
It was a 3/16 rod. I tapered the end 5 degrees so it fits nicely on the taper. The rod is the spring. You put the rod in the hole and then push the locking block forward a little to apply spring pressure. It's amazing how well it works.
Jerry Maske
Jerry Maske
Thank you, John. I just bought one of these and haven't set it up yet, but it's high on my ToDo list. I talked with a design engineer at Jet and he was embarrassed about how poor their index system is. He said he didn't know ANY lathe that came with a decent indexer. Not sure about that but it didn't speak well about what goes into lathes at the factory, especially the Jet.
I Rough Turned a handful of Maple bowls all with the idea of doing symmetrical carving or wood burnings on them. They are all dry now so it's time to get after them.
Jerry
John C Lucas
Most lathes have mediocre index systems. Most people dont ever use it so i guess they dont put much time into the designs. The Alisam and Ironfire index are much more veritile and easy to use.
You're amazing John-excellent work.
Don Orr
I'm sure we will all be stealing this idea at some point.
Re: You're amazing John-excellent work.
John C Lucas
I didnt think this one up. Someone posted it on WC a while back.. i can't search on my phone to find it. I modified it slightly.
I remember several threads about 10 years ago about indexing wheels. Could it be this one from 2005? Unfortunately the photo is gone from the archives so it's hard to visualize the mechanism.
http://www.woodcentral.com/woodworking/forum/archives_turning.pl/bid/2105/pro/search/pmd/sread/srchid/28322u7ydzoLr15eVSa91458065933/spage/2/sanc/73377/sbid/2105/md/read/id/73377/sbj/indexer-finally/
This was a related thread:
http://www.woodcentral.com/woodworking/forum/archives_turning.pl/bid/2105/pro/search/pmd/sread/srchid/28322u7ydzoLr15eVSa91458065933/spage/1/sanc/64579/sbid/2105/md/read/id/64502/sbj/indexing-plate/
John C Lucas
This was just a few weeks ago although i lose track of time since im hanging out at the hospital with my dad. Its possible it was on WOW or the AAW forum. Id just like to give credit where its due ..4
