Help with 3520B
Help with 3520B
Help with 3520B
John Kaner
Are there supposed to be exposed threads between the hand wheel and headstock? The set screws are tight... Is it slippage over time, like a Jet Mini?
Loosen set screws and thread hand wheel closer, tighten set screws...
Any help is appreciated!
Re: Help with 3520B
Re: Help with 3520B *LINK*
john Lucas
It's been a long time since I had the handwheel off my 3520A but I'm pretty sure it has nothing to do with bearing or spindle tension like on the Jet mini. I'm pretty sure there was a separate threaded locking ring that you tension. Here is their parts list on the B series and seems to match what I remember on my A series.
http://www.ereplacementparts.com/powermatic-3520b-1352001-tefc-2hp-220v-woodturning-lathe-parts-c-32549_32637_32638.html
Re: Help with 3520B
Re: Help with 3520B
James L
Hi, I just went and looked at mine. I can see the crown of four threads between the locking ring and the handwheel.
Re: Help with 3520B
Re: Help with 3520B
John Kaner
Thank you John for the diagram and James info on your lathe.
