Carbide tipped bandsaw blade
kruizen
Has anybody here tried Lenox carbide tipped bandsaw blades on "wet" wood?
How did it work?
Which tooth pattern did you try or use?
Re: Carbide tipped bandsaw blade
robo hippy
I asked my dealer about them and he said they are really only for cutting fine veneers. I tried one on my big saw, and he was right. They can not be resharpened because the carbide tips are so small, though a diamond hone might touch them up. I do use the bimetal Diemaster blades for all of my bowl blank cutting.
robo hippy
john Lucas
I ruined one in a heart beat. Don't recommend them for Green wood. I use the cheapest blades I can find because unless your extremely careful with how you hold the wood on the lathe you will bind up a blade every now and then. When that happens there is a very good chance you'll bend it making it very dangerous to use. My local blade sharpener makes 152" 1/2"x 3TPI blades for me for $9. When I bend one or it gets dull I just toss them. I save my good blades for dry wood only.
Dick Coers
I've not used one, but I understand they have almost no set to them. Not a good thing for wet wood.
Re: Carbide tipped bandsaw blade THANKS
kruizen
Thanks for the info!
Dave Stricker
John, where do you buy your blades? I'm looking for a local source.
