Re: Segmented Sanding Sled
ebd
Instead of trying to get the segments right after the fact (after they are cut) I would (actually did) make a sled to cut them perfectly in the first place. I made this one (http://www.turnedwood.com/framesled.html) and spent a long time making test cuts till I got the adjustment exactly right and then locked it down - never to be changed. I've been using it for a lot of years and never had a ring come out other than a perfect fit.
I modified the design a bit. First I made it on a thick acrylic/plexaglass sheet. I used a 2" thick piece of wood for the fence and attached two toggle hold downs on it. One to hold the stop (so each segment is the exact same size) and one to hold the piece getting cut (so there is no chance of movement).
It worked so good that I made one to do perfect 45° cuts and I'm thinking of doing one for perfect 90° cuts. Nothing beats being able to pop a sled onto the table saw and know, without any test cuts or other fooling around, that the cut will be exact - no fuss, no muss, no time wasted.
I don't have time right now but later today I will take a picture of my sled and post it.
