I got several grades a year ago from super thin to medium and all of them got thicker and thicker until they were useless. Forgot the brand, sold by an asian person in California.
I have used Stick Fast and Hotstuff for a long time. I've had only a 1/4 of one bottle of medium Stick Fast go bad in maybe 15 years.
A few months ago I bought some from Mercury Adhesives, made and bottled entirely in the USA - I was impressed with their information and product: Mercury Adhesives
Thanks, JKJ -- I'll look them up. CA lasts a long time in my hands; I store unopened bottles in the freezer for up to ~ 14 years with no problems (I warm them up to room temp before opening them), but clogged tips are another matter.
I put unopened bottles in the fridge with the caps on. I don't bother to let them come up to room temperature. The bottles last so long the plastic starts deteriorating before the glue is gone. I finally threw away one bottle I had since before I moved here to the farm in 2003; the tip was cracking and the glue was almost gone anyway.
I leave one bottle of thin glue out on the shelf with no cap. I do keep one of those tiny capillary tubes on it that let you put a tiny drop exactly where needed. Maybe that limits the moisture movement - this bottle has been open for over a year and is about 1/2 gone. Or maybe the humidity is just low in the shop with the AC in the summer.
The one medium thickness bottle I mentioned that the last 1/4 thickened up was the exception. I decided to try leaving it out in the room instead of returning it to the fridge. I don't think it lasted a year. Back to the fridge method for medium.
I have very little trouble with the glue clogging the tips. After use, I hold the bottle upright and squeeze to blow the remaining glue out of the tip. For the capillary tips I run a tiny wire through which cleans the sides. Eventually those capillary tips degrade so I stick a new one on the bottle. After I started using those tips I hate to use thin CA without one.
The Mercury CA bottles have a stainless steel pin in the cap that prevents clogging. They also claim to use plastic formulated to prevent moisture from permeating through from the outside, a problem with the plastic used for most CA glue bottles, according to them.
I think some CA glue is junk. I bought a bunch of cheap glue once and had all kinds of problems with it, including weak bonding. I save it for flooding punky wood.
I am not a big user of CA glue but am using Titebond. I keep them in a refrigerator and generally use them shortly after removing. I have had no problems with stopped up tips nor glue deteriorating. I tried some other brand whose name escapes me at the moment but was disappointed so returned to Titebond. Suits me to a T.
>I think you should ask the "Mercury" people the name of the USA company that
>makes the chemicals their product is made from and the country of origin.
Have you heard something about this? They claim their glues are manufactured and bottled in the USA whatever that means. Somewhere I found a technical write up describing their R&D facilities but I can't find it just now and I'm headed out the door.
I do like their warranty:
"unconditional/unlimited guarantee on all newly purchased CA. If it hardens, we’ll replace it."
This is where I get mine and the price is right and the glue works just fine for me. As others do I keep it in the fridge when not using and have kept the large bottle with varying amounts for a couple years with no problems. I also order some extra bottles and the caps and use the large bottle for the refill, a good number of caps.
Ben, I think Wooden Wonders actually picked up the E-Z Bond line. I have been buying from E-Z Bond for years, as has my club. Compare prices. Example 16 oz. bottle you pay 28.33 and I pay 16.90 for exactly the same thing. Thats 11.43 difference. Its E-Zbond.com
