Turn a ring with a u-shaped cross section, then cut the ring in half and glue them together to form a 180 degree hollow tube. Pretty clever!
Now I want to make a bugle. (Like a trumpet but without the complexity of valves!) I suspect 80% of the effort was in the precision valves and making all the extra tubing to switch in and out.
I notice that it doesn't have the valve to blow out condensation. I can't imagine it plays well as temp would change pitch and condensation would make it impossible to tune. Very difficult project skill wise, and beautiful - but not especially practical IMO.
You are right, this is not the LEAST bit practical! I think Eric Gourieux, who made this trumpet and the guy who did the wooden french horn in the American Woodturner magazine certainly did - he referred to his piece as a "sculpture... made for display." These instruments probably have as much functionality as a lot of the other "art" pieces I see. :-)
Besides the dampened resonance in the tubing and bell and the problems with moisture, I think another big issue with making a functional copy of a brass instrument is the ID of the tubing. Since the wood tubing is much thicker than brass, you would be faced with either making the ODs match a "real" instrument for looks at the expense of restricting the air movement (which is critical), or keeping the ID correct and making a "fat", distorted-looking trumpet!
BTW, some brass instruments are made without water valves. The expectation is to tilt or remove a slide to drain if necessary. One of my French horns had no water valve until I bought one and soldered it on while doing some other mods. For the horn it may not as critical since to remove all the condensation still requires a procedure involving rotations and valve operation. I have a bugle here with no valve either, just needs a tilt to drain. Since most of the condensation occurs in the lead pipe, the same should work with a trumpet.
Here's a note from the guy who built the wooden french horn, Murry Stein:
The Oct 2015 American Woodturner magazine has a fantastic article by Murry about the why and how of making a wooden horn. A beautiful job and with yellow pine from his scrap pile!
