band saw blade tension lock-up
bill tucker
This has to be in the catagory of "simple, but just can't see it". Always tighten the blade tension to use, and loosen when finished. Started to loosen as usual by turning the top knob and it started to bind up. There is still tension on the blade, but the knob refuses to turn. Shots of Kroil (like wd-40) refuse to free it up.........ideas??
thanks,
bill
Re: band saw blade tension lock-up
Dick Coers
What brand bandsaw are we talking about? On the Delta, you can see the end of the adjustment bar and if it is still contacting the machine or is loose. Can you turn the rod either direction? If that is bound, you likely have a stripped thread. Where did you spray the Kroll? Only two options really, the tensioning rod and the slide mechanism.
bill tucker
Sorry, should have been more specific. It is a Jet 14" and yes the end of the rod is still in contact with the cast iron. You're right, though I hope not, the rod does act like it's stripped. It's a captive system so not sure how that can happen.
bill
Roger Chandler
Dick is probably right about the slide mechanism.......what happens is that at times when the blade is tensioned, the corner of the slide will go above the edge of the hole in the back cover where the hub spins on the shaft of the upper wheel, and that can sometimes be just enough to cause the saw to not release its tension because the downward motion is blocked by the edge of the back cover where the hole is.
Take a flat screw driver and put just a little outward pressure against the slide, and it should clear the hole edge on the back cover, and then you should be able to take the tension off.
Warren White
I have the same bandsaw, and had the same problem. The threaded rod was stripped in one place, but i was able to rethread it and it has worked just fine since then.
bill tucker
Thanks for all of the help. As ya'll suspected, the nut had gotten cross threaded somehow and the threads were stripping. Just got a new rod and nut and will install in the morning. Maybe I need to think about one of those tension release lever mechanisms.....what do ya'll think.
bill
Pete in Holland MI
All of my machines that have threaded adjustments get greased during assembly, and occasionally afterwards. Not lots, but just a bit. Threaded fasteners have a lot of shear action going on in the interface of the threads. Constant use will destroy the threads of the softer material of the two.
Pete
Or stop detensioning
Dick Coers
Controversial these days, but maybe 15 years ago or less, no one ever talked about taking off the tension. I haven't taken off the tension in 40 years and have never seen any problems.
Ditto   I don't relieve tension either
I have had the rod strip the threads on my aftermarket 14" bandsaw. I bought the Delta used from a friend who used it professionally and I used it for 10 years. Didn't strip the threads on that one. I did build a detensioning device but it didn't work as good as the commercial ones so I took it off.
I now have a 16" bandsaw and it's work to detension so I probably never will unless I see some kind of problem later on.
