what carbide tool for woodturning rough turning
Larry
What kine of tip ( Round,or Square or?) carbide tool would you use for wood turning rough ( from square to round) ?
Thanks
Larry
Thanks
Hunter Hercules *LINK*
I played all day one time roughing out really big out of round pieces of wood and switched back and forth between a 5/8" bowl gouge, and the Hunter Hercules. The Hercules put less stress on my shoulder. I used it as a scraper at first. Then when you get the bowl shape closer to what you want use it in a push cut bevel rubbing mode for a really clean finish and better control over the shape.
This one tool will do both the inside and outside. It cuts cleaner and stays sharp longer than the other carbide tools. I have some of the other brand tools and was surprised how quickly they lose their edge.
The tool is somewhat short overall so I put a long handle on it to give me more leverage and better control during the roughing. For finial shaping and cleaning up cuts I prefer the Hunter Osprey. It has a round shaft instead of the square one of the Hercules and I find it easier to control for finishing cuts. The Hercules will do these cuts. Simply tilt it the same way I would use the Osprey.
Go to www.youtube.com and type in John60lucas/Hercules and you can see how I use this tool.
http://huntertoolsystems.com/
Re: Hunter Hercules video *LINK*
https://www.youtube.com/watch?v=vzrLN8SQ8ms
Re: what carbide tool for woodturning rough turnin
Jim Breeden
Hunter! Yes, I was skeptical since I have the "other" kind of carbide. I was at the last Rocky Mountain Symposium, met Mike Hunter and bought the hollowing tool - wow - cuts like butta!
UnEasyWood
I bought some Easy Wood Tools (roughing?) at a symposium soon after they first came out, two sizes. Never used again after the first test.
I'm sure they have their value but for what I wanted the difference between these and other carbide tools is like smoothing with an axe vs a good plane. (IMHO)
Just taking up space now. Maybe I'll give them away if someone wants them. I think I have some extra cutters somewhere and the little chip shield. Or, how about a WC benefit auction?
I have a pile of Hunter tools (not literally, that would chip the cutters) and can't say anything but good about them. Been using them for years and recently added the Osprey and the small hollowing tools. Well worth buying. Besides, Mikey is one o' them Real Nice Guys.
Re: UnEasyWood
Jerry Maske
The EWT line has it's plus sides but it's not meant to replace your regular tools. I use the rounded tool, the finisher, a lot and it is a sweetheart. The detail tool, likewise, gets a lot of use. Never tried the square one yet. David Ellsworth taught me how to rough wood and I've never looked back.
Don't throw those EWT away until you've spent a little more time with them.
Re: UnEasyWood
I've spent more time with them. I don't like them either. I can cut so much cleaner with a spindle gouge than the detailer will ever do. The round tool is not bad but a fresh burr on a round nose scraper will cut cleaner and the Hunter tool cuts cleaner and the edge lasts far longer.
The only real advantage is they have zero learning curve although quite often the shapes produced shows that. You also have to start sanding with a much courser grit. Once you really learn how to use a bowl gouge your shapes will be better and you can start sanding with much finer grits which not only saves time and mess but helps you keep any crisp details you put in a piece.
Re: UnEasyWood
Jerry Maske
Okay, I stand properly chastised. For sure, I agree with what you said. And I use all the "Traditional" tools to do all that stuff. My bride, however, does not, and the mini set is perfect for her. She's never been a fan of gouges. I do my best to change that, but have NOT been successful. In her hands, the EWT set is a blessing. I don't have to think about what she might be doing that could hurt her or if she's bothered to sharpen my tools she dulled! Marriages are filled with concessions.
In any case, I don't think the EWT set was ever intended to replace traditional tools. But there are times that the finishing tool will get into an inside space under a rim a whole lot easier and cleaner than anything else I've got on the rack.
One more tool in the tool box.
Re: UnEasyWood
Ron Bauer
If I am not mis-taken the question was what to use for rough turning. Personally I use Cap'n Eddy's round carbide cutters for roughing. They are inexpensive and extremely durable for roughing. They are not intended for the same use as Hunters. Besides, Cap'n Eddy is a nice guy too.
Re: UnEasyWood
The Easy Wood do rough, and aggressively, but the problem for me is the cutters are too big. A big bite is rough on the wood and rough on the turner.
Re: UnEasyWood
John C Lucas
I do agree. When I teach big classes there are always 1 or 2 people who just ca t get it with bevel rubbing tools and even with nice can't sharpen. For them the FLAT CARBIDE TOOLS would be much easier. Those same people aren't as picky about shape and just assume starting with 120 grit is normal.
Spindle Roughing Gouge
Brad Vietje
...why would you want to use a scraper on a spindle?!?
The Hunter tools are true bevel-supported cutting tools, so they cut like gouges, but the flat-top tools, carbide- nano-carbide- or otherwise, are scrapers, and IMSNSHO have no place in spindle turning.
Just one fella's "sometimes-not-so-humble" opinion, and worth no more than you paid for it, but you won't find me putting a scraper on a spindle blank unless I had no other alternative.
Safe spinning,
Brad Vietje,
Newbury, VT
Re: Spindle Roughing Gouge
Ron Bauer
When I drop the handle it becomes bevel supported. Again, the question was about a rougher. Furthermore, while I will use it on between center work it really works great on bowl roughing.
Re: Another vote for Hunter Tools
Steve Criscenzo
I do most of my rough work with a gouge but when I need fine finish cuts, particularly in difficult wood, I reach for one of my Hunter tools. The Hunter tools cut rather than scrape and the configuration of the cutter allows a benificial approach angle. I have the Easy finisher tool and I do use it at times but mostly for removing larger amounts of wood. I do not find the scraping cut useful for the finishing cut.
It is understandable why less experienced turners find the Easy tools useful. They are forgiving and can remove large amounts of wood quickly. I personally prefer a gouge or a Hunter tool but I do not think we should pan a tool for everyone because it does not fit our work style.
Steve
Re: UnEasyWood
Ron, it looks like somehow a "close underline" HTML tag was messed up in your message, underlining the messages on the rest of the page! Maybe adding one here will fix any messages after this one. JKJ
(edit: nope, I can't fix it - tried two forms)
(edit: ah, underlined then edited one tag, that worked at least once!)
(edit: then it reverted! one more try then I quit)
John C Lucas
Ditto I did a test a few years ago on spindles to answer a question. The question had to do with using a scraper without a burr and rubbing the bevel. For my test I cut cover and beads with a spindle gouge ,a scraper, the same scraper with no burr, and a scraper with no burr but ground at 35 degrees the same as my spindle gouge.
The scraper was the worse with torn grain at the bottom of coves and torn points where 2 coves and together. The same scraper without a burr used as a bevel rubbing tool was a little better but still had noticeable torn grain and torn points. This scraper had about a 60 degree bevel. Then I revround it to 35 degrees and used it without a burr and rubbing the bevel. The it was extremely similar to my spindle gouge. Repeated.The test on different woods with the same results.
Lloyd in Mississauga
So I guess with the scraper sharpen to 35 degrees it was much like a fluteless gouge or skewgy gouge (sp??).
From Lee Valley's web site (http://www.leevalley.com/en/wood/page.aspx?p=46298&cat=1,330,49233,69094&ap=1)
Exactly
Lyle Jamieson
It is a shame that a tool is advertised to do something it is not good at...finishing.
