A55 Smoothing Plane
routed technique I'm working on.
This may be hard to explain. I route 16 (in this case) V grooves in the end grain of 2 pieces. They seem to fit perfectly together. However when routing straight across the bit cuts tapered V,s so the middle is lower. It looks kind of like an orange squeezer you use to make orange juice but concave. When you put the two together only the outside is really glued unless you use a gap filler type of glue. Of course then you can't reduce the size very much or the glue gap shows.
I rotated the router guide to about 8 degrees and then you still have the tapered V,s but now the middle isn't recessed. However now the outer edge won't seat because the middle is touching and the V,s are really shallow. I still glued one together with colored epoxy and will try and turn that tomorrow to show you the results. The gap looks pretty cool.
So I tried rotating the table about 2 1/2 degrees and then hollowing the middle. As you can see in this photo there is still a gap on the inside due to the tilted V,s. I'm going to go back and try the 8 or 9 degrees tomorrow but hollow out the middle and see if I get at least close to a closed gap for 1/4" or more. I was hoping to get it all the way to the middle but that won't happen.
As you can see in the first photo the outer edge meets perfectly. However just 1/2" in you can see how large of a gap you get. That's with the table swung 2 1/2 degrees from the outer edge toward the middle so the router is routing a tapered groove. Well that's not accurate because it's always tapered but this way the middle isn't as low as if you route straight across.
Re: routed technique I'm working on.
Getting close
I've been experimenting since about 5 this morning. When I get a bug like this I can't stop till I solve the problem. I tried 9 degrees and hollowed out the center. Didn't work. Then tried 5. Much closer but had a gap on the inside and outside. This happened because the router bit wasn't cutting absolutely dead center. I was off less than 1/16". Changed shims and got it as close as I can. Then tried 4.5 degrees. Extremely close over a distance of about 1/2". Gonna go try 4 degrees and check to see how close my bit is to center.
Well I tried. 4.5 or 5 degrees is really really close. The problem is there are 3 critical factors that may be beyond what we can do in woodturning. You have to be absolutely dead center. The depth of both cuts must be dead on, and the angle (which I'm still trying to discover but is somewhere around 4.7 degrees) must also be dead on. Without using a metal lathe I don't think I can control the 3 elements to the degree needed. Still I learned some interesting techniques which you will probably see in the next few months.
Re: Getting close
This is fascinating. When you first described this I wondered about the critical alignment. I am quite interested in hearing more.
Tony - Memphis
Nice. I was thinking about something like this recently. I made a laptop stand with an adjustable top. The "squeeze" mechanism I made didn't squeeze enough to hold the top. Thought something like this would work. I've seen this arrangement on some other similar applications. Next time..... I ended up using pins and only offering two settings in the end.
Tony
Lloyd in Mississauga
John,
Instead of using a pointed cutter, have you tried a wider straight cutter and put the router on a 45? Since it is the outer edge cutting the bottom of the V, you may get a cleaner deep cut there than with the V cutter shape where the centre is not rotating very much.
One of the guys at our club who uses a 3D end mill for his lathe, does this when he is building up segmented rings and wants to have V shapes.
