A discovery about lathe alignment
I discovered something yesterday. It appears to me that two supposedly identical lathes may not have interchangeable headstocks/tailstocks.
I have two Jet 1642 lathes in my shop. A few weeks ago a VFD failed and while it was down I moved the headstock from the second lathe over to my primary lathe so I could keep playing.
When turning some small finials with tailstock support I ran into vibration problems so I checked the alignment between headstock and tailstock. It was off by almost 1/16"!! Ack.
I tried jacking on the lathe legs but it would not get it close enough. Finally I swapped tailstocks with the other lathe and alignment was perfect.
Are these things made in aligned pairs? Are the tolerances so bad that someone at the factory has to try 15 tailstocks until they find one that is close? Perhaps a change in setup at the factory prevents interchange of parts from a different production run.
Maybe everyone kneew about this but me! One more thing to think about.
