Another little "Brad Vietje" ornament
My second experiment using basswood to turn a quick little ornament as per Brad Vietje's instruction. Used a smaller scrap of wood than the first one.
If you haven't seen it, the video is here:
This was from a scrap of basswood, smaller than the first. Since I didn't have paint/markers that would work I tried colored pencils. Used a texturing tool on the tree before turning the off-center groves with a skew. No sanding used. I figured out how to hold this one to turn the bottom cleanly. Sprayed with satin lacquer, 5 mm eyelet screwed into the top.
Things I like: the profile, the texture, the color, the size, the weight.
Things I don't like: the base (too thick) and the torn edges. The tearout is all on places where the texturing tool crushed the wood grain. I think these could be prevented by applying some kind of finish like sanding sealer to "glue" the fibers before cutting the grooves. I may try that next time. (This seems to work well for chip-carved basswood.)
These are real easy to turn and very quick. Maybe I'll try one from a slightly more forgiving wood than basswood.
This is about 2.5" tall.
Thanks again, Brad!
