THE WOODRAT IS BACK!
UV light for wood ID
For those interested in wood ID with a microscope and otherwise, a good UV light is helpful in some cases since certain species fluoresce uniquely. The problem is acquiring a good UV light.
A 365nm UV light seems perfect. If it is too long a wavelength, i.e., closer to 400nm as most of them are, there is too much white light which overpowers the fluorescence making the light nearly useless.
The people selling these lights seem to substitute whatever they can get for what they advertise, or just outright lie. After buying several cheap lights, some which were good and some worthless (and being a pest until one finally sent the correct light), I finally found an excellent UV light, courtesy of some posts on the Candlepower forum.
This one is advertised as 365nm and I believe it. It is well made and very bright: EagleTac P200LC2 365nm UV, uses CR123a or the rechargeable 18650. About $60.
http://www.amazon.com/gp/product/B014AYMBMQ
NiteCore also advertises one that is the same size and probably more useful with both bright white and UV but it costs more or I would have bought it. (I have another NiteCore I really like, small, 1000 lumens, and well designed UI - even has a built-in voltmeter to monitor the battery!)
Here is an example with honey locust and redheart. Black locust and honey locust fluoresce a bright greenish yellow. Redheart glows bright orange. The cell phone photos below are not exactly what my eye sees, but you can get the idea.
I just turned some redheart finials for ornaments and I can see every shaving bright orange in my bin.
The UV light is also good for checking US bills, and reportedly good for spotting scorpions and pet mishaps.
Re: UV light for wood ID
Slight side track. I just borrowed a huge hand held spot light form a carpet cleaning company to spot pet stains in a house I am flipping.Did not work as well as I hoped. Had to have total darkness and even then the urine crystals were not obvious. Maybe my expectations were too high. How about giving one of your dogs a little squeeze and see if the urine fluoresces?
Did you turn the lights out for the shot of the wood?
Brad Vietje
Brad Vietje
Mature's Miracle is very good for "pet odors" especially urine. Available at pet supplies or your local vet. Good stuff.
Brad Vietje
Newbury, VT
Brad, I tried that. Believe me I tried. This is the second house I have bought with a urine odor problem. In the first one I used gallons of Nature's Miracle. And everything else I could think of. Ended up tearing out 400sf of floor and all the sheet rock up to about 16" high. And the duct work under the floor.
This time I was determined to do it with out the replacement. Went to a carpet guy who specialized in removing pet odors. Did research on the Internet. Found Hydrocide. One quart of it ($26) did the two rooms and killed the odor. Sprayed a gallon of Microban inside the cabinets and on the paneling that had nicotine. (Rough sawn paneling, no way scrubbing would fix it.) After the floors dried I painted them with oil based Kilz and then covered them with polyethylene for good measure. Done. DONE I tell you. MUCH faster easier and cheaper than tearing it all out.
Maybe the cats will pee on the wood and we can see what that does.
You absolutely need to view fluorescence in the dark or the ambient light will overpower the weak glow.
As for wood ID, sometimes water or alcohol can be used to enable or enhance fluorescence. The problem I find is lack of a definitive reference. Some have conflicting information. The Wood Database has a link to a list in their wood ID article:
http://www.wood-database.com/wood-articles/wood-identification-guide/
I am slowly building my own library of wood samples prepared as per Hoadley for ring/pore exam with magnification. (I use a fantastic and inexpensive lighted loupe as well as a low power stereo microscope. I'm hoping at this grows I'll have more fluorescing samples to use for comparisons.
Sumac is another one that floresces
