Latest Lampshade
Latest Lampshade
Brad Vietje
Latest Lampshade
Brad Vietje
Some warm November weather, and my brandy-new Oneway face plate gave me a chance to try another lamp shade out of Big Tooth Aspen.
Step 1 -- trim log to fit on lathe -- from about 95# to about 65 pounds; that a 20" bar on the saw:
Then shape the outside and begin thinning the inside:
Nearly done (but how the heck do I get this thing off the faceplate???):
And two views of the almost-finished shade. No finish yet, just bare wood. will probably soak it with Watco (since that's what I have), which will make it more translucent. This one seems a little thick (dark), but it may lighten up after oiling.
Propped crookedly on an Arts & Crafts lamp:
... and hanging above the dining room table:
Fun to do, but a real workout! I still need to figure out how to finish these off and get 'em off the lathe w/out nicking screws (more waste wood would help!) or busting it. Still working out the process.
Safe spinning,
Brad Vietje
Newbury, VT
Re: Latest Lampshade
That's incredible. I want to make one of those when I grow up.
Rum
Clap Clap Clap!! Bravo!
Something I'd like to try someday but have thus far lacked the courage.
Are you using hook/ring tools for the inside or more standard hollowing tools?
Good job Brad
I think I'll start with a really small one.
a really small one
You mean about the size of your "small" goblets?
Now that I might be able to handle.
Brad Vietje
Brad Vietje
Thanks, Rum.
I have not used hook tools on full-size shades, since I have only learned to use them to cut outward from center. (I have Martel and Wolok hook tools, but have never tried the old-style traditional hook tools like Robin Wood) I have used a ring tool or a captured ring tool like the Exocet to remove bulk end grain, but this time it was all bowl gouge for bulk removal, some spindle gouge to thin/smooth it a bit, then teardrop scrapers to finished thickness.
I need to get a few more of the tantung scrapers, and at least one more light to make this process a little more efficient.
Safe spinning,
Brad Vietje
Newbury, VT
Rum
Thanks Brad,
The finished cuts looked really good so I was wondering..
I've noticed that you're handier than average with the spindle gouge from some of your videos so I can see why you'd use that. I don't think my inside shear scraping is quite up to tackling something like that yet either.. Impressive work altogether.
