shots of my new shop
It's a long way from done but really starting to come together so I can do work in it. I'm down to probably 10 boxes to unpack. All smaller stuff except the box full of Dremels and flex shaft machines. Most everything else will go in drawers except the clamps. I have over 100 of those and not sure where they are going yet.
This is probably the heart of the shop. The bandsaw and lathe will get the most use. Just about everything else is there to support these although I will be doing some more flat wood projects.
Looking toward the sharpening area and workbench. Still think I need to do some arranging in the sharpening area but not sure what to do yet.
Looking over the table saw. The miter saw is behind the tool boxes. The thickness sander, belt sander and planer will all share the same dust collector hose hanging down to their right. I'll simply roll those machines where they will work, connect the hose and be working. I don't use them as often so I thought that would work. To the right of that under the window will be a carving workbench with a sort of down draft table. All my carving stuff is in the red cabinet. Behind this area outside is a shed that holds my dust collector and air compressor.
Here's a better picture of that area. I have my oscillating drum sander on the left and on the right behind the drill press are my 1" strip sander, 2" belt sander, 12" disc sander. The flex shaft tools and dremels will be located on a stand beside the soon to be built carving station.
this is my metal working area. There is a hydraulic press, horizontal bandsaw, and Smithy lathe/mill. I still have to put a cover on the concrete slab that is out that door but it will have my Blacksmith area with a forge, anvil and also my shaving horse.
There is a room to the left of this area that will have all my parts and other odd stuff. It's 11x23 Metal supplies, nails, screws, rope, glues, paints, tape, and probably in the long run smaller wood supplies for the boxes, hand mirrors, ornaments and other things that don't take up a lot of room. Outside this area and to the left of the Blacksmith area is my wood storage building. This isn't ideal but will have to do. It's a roughly 12x 16 room that I'm putting all sorts of shelves in to help sort out the wood.
Definitely the biggest and best shop I've ever had.
Re: shots of my new shop
So nice, and very bright! I like the toolbox dedicated to carving - I need to do that.
What size is the main shop? Did you add up the floor space for all four rooms?
Main shop 24x30
David Walser
That's a very nice shop and a nice collection of tools. I'm sure you'll do a lot of good work in it.
I forgot to say that I plan to build a cabinet for the miter saw and one to go under the tablesaw. Also need a rolling cabinet for the vacuum pump since I use it at both lathes and the workbench. Plan to build a few cabinets for the wall but as you can see I took up most of the wall space with windows and dust collection.
Doug Ladendorf
I'm impressed John, you have a lot in there yet it still seems very comfortable. Great dust collection, a metal working area and blacksmithing! Well done. I'm sure it will be a pleasure to walk in and just start working.
Doug
Wall space
Hey! For all that extra time you have: get rich designing a series of cabinets and storage things for the wall space impaired shop! Might require thinking outside the boxy cabinet, perhaps with help from a brain-storming session with some shop buddies whose creative inhibitions are softened by some type of liquid refreshment...
Wall cabinets with DC ducts built in the back (maybe not round but wide and flat). Window box cabinets that mount high over a window with reflective space behind that channels daylight down and/or up into the shop. Ceiling mounted cabinets that lower with a button push. Clamp racks against the ceiling that hinge down for access. Narrow "pocket" cabinets or tool racks that slide out of a recess in the wall. Lazy susan hex or octagon cabinets mounted high in a wasted corner with multiple doors. Go wild.
Or how about cabinets for those who want an outside view without sacrificing the wall space - fronts of flat screen monitors with camera outside. Could do double duty for sports-a-holics. :-)
A friend of mine actually had the cabinets that lowered so he could reach them from his wheelchair. I don't think they were cheap but his government employer installed them in his home office. His were mounted high on a wall but clever engineering could recess them into the ceiling between studs.
OK, I'll quit now.
Fantastic !
Don Orr
I hope your new shop provides a lifetime of happiness.
My only question:
David Walser
Where are all your students going to turn when they come to the John Lucas School of Hand Mirror Making?
Ha Ha no more than 2 students
Dennis in Southern Oregon
John, I put my vacuum pump in the same anteroom as the dust collector and the air compressor, and plumbed to the lathe with copper tubing. This avoids the annoying noise of the Gast pump and probably is less work than building a cart for the pump, and takes less floor space. It shares a remote control switch with the dust collector. A manual switch in the anteroom lets me choose whether the pump, the dust collector, or both run when the remote control switch is activated.
John L, if you want to try this on the cheap, I have leftover 1/2" plastic line from running air lines in my shop. It's very tough and difficult to bend - think it would easily be strong enough to hold a vacuum, ain't no way it will collapse, methinks.
Dick Hines
Re: Ha Ha no more than 2 students
Dick Hines
Seeing your clean shop makes me want to come buy and spread shavings all over the place. A shop is not suppose to be that clean.
Mark Paulley
John,
OMG!!! This is a dream shop. All of the toys and plenty of space.
Shop a bit too clean for me but awesome looking!!
Very envious!
Philip Duffy
Looks very professional and tidy!! Put some chips on the floor and resubmit! Philip
I"m going to try really hard to keep it clean. I know there will be times (maybe even a week or more) when I'm really involved in a project or roughing out lots of fresh wood. Sometimes it can't be helped. But I've convinced myself that when I have a clean shop my work shows it so I'm going to try.
lee tourtelotte
John -- FYI
Since you mention you are going to build a miter saw cabinet, there is a great plan in Shop Notes, for a folding, movable, miter saw cabinet that has many desirable features, including controlling the thrown sawdust and fold down extension wings for sawing long boards. It is in Shop Notes, Volume 22, Issue
127., p20-29. (Jan/Feb 2013) It states: A "Dream Shop" Project! Since you now own a "Dream Shop", you best check this plan out. If you have trouble finding this issue, let me know & I will mail you a copy.
Lee Tourtelotte
Minnesota Woodturners Association
leetourtelotte@msn.com
thanks. I saw that in the store the other day. Not what I want. I have cabinets on both sides to support long boards. I am going to build a dedicated dust collector chute behind it. The cabinet itself will be on wheels for the possible rare need to move it but also because If I ever move again I want to be able to just roll it in the moving van.
John Jordan
Congratulations, John. You've built yourself a great workspace and its well deserved.
I expect my Christmas present will be really special this year. :)
John
Mike Gibson
Great Job John, For your shelving Home Depot carries shelf brackets that stick out 18" and they are heavy duty can carry a load. They are a little hard to find in the store but they are there.
Reminds me of the time the director walked into our meeting and asked everyone "Well, what did you get me for Christmas this year, and why not?" :-)
