finally have dust collection- shop is almost ready
I can start working now. I still have lots of little things to do and cabinets to build and many more boxes to unpack and put somewhere but at least most of the machines are ready to go. I'm very happy with the dust collection at the bandsaw. I put a separate hose at the top where there is a hole for the blade guide to go when it's raised. a lot of dust goes out that. I built wood covers to go under the table that are held on by magnets. this reduces the air gap quite a bit and they can easily be removed if I have to tilt the table.
I have ordered some of those flexible hoses that stay where you bend them to go to the drill press. The hose that goes to the mini lathe also goes to a floor sweep. Most of the time that lathe won't be used so I can hook that hose up to smaller hoses to vacuum machines, lights etc and of course the floor sweep. When I need it for the mini lathe it will be quite simple to attach it to that.
l still have a few things to hook up. Had to order a few more supplies to make that possible. The hose hanging down in the middle of the room will have quick disconnect adaptors so it will instantly be used for the thickness sander, the belt sander, or the planer. Just roll them into position and hook up the hose and power and they will be ready to go.
It's not as quiet as I hoped. I guess all that air going through metal pipes creates quite a bit of noise. Still it's far quieter than before.
