THE WOODRAT IS BACK!
ornament save trick
ornament save trick
ornament save trick
I love to turn punky wood for ornament spheres. Sometimes the little tenon will break off do to either weak wood or if I get too carried away when hollowing and make the top too thin which breaks. This leaves me with a ragged hole in the top. I hate to throw those away so I came up with a way to save them.
I use a hole bit designed to drill clean holes in sheet metal. I simply center it as best I can and then drill a hole until it gets large enough to clear all the torn areas. Works great. You just have to remember to make the top finial larger to cover the hole.
here is a shot of the bit and the ornament I saved.
Re: ornament save trick
Brad Vietje
Brad Vietje
Nice idea, John. I have a few of these stepped bits, which every electrician uses to put proper-sized holes in metal and PVC boxes.
For anyone going out to buy one, watch the prices! I once got a Greenlee bit from an electrical supply along with 20-30 other items for a job, and didn't realize the price was $72 until I looked at the receipt the next day to return an unused item. OUCH! They are normally ~$20 - $35 for good ones. This one must have been made from platinum.
Safe spinning,
Brad Vietje
Newbury, VT
I got mine at the flea mkt.
