A55 Smoothing Plane
Shop is really getting set up
Came home after church and started working on the bandsaw. Got is all set up and in position and then turned it on. Nothing, bummer. Did I wire something wrong. Meter probes aren't long enough to read inside the socket so I unscrew it from the wall and take a reading. Nope, not me, I have 240. So I remember that this bandsaw has lots of interlocks. I open and close doors and step on the brake several times. Whala, POWER. It was missing one of the leveling set screws. Don't know where that went. I grabbed a bolt of roughly the same size and turned it down to the thread pitch size (yea my metal lathe is working also). Rethreaded it metric and installed. Leveled the bandsaw.
So then I get excited and start moving some of the rest of equipment where i think it might work. Plug them in and clean them up and they all work. Then I had to re-assemble the Jointer and align those granite beds. Took a while but it's up and running.
Man things are moving along. Still have a huge amount of things to unpack. Have to fix the bottom of my router table. guess the feet got damaged in the move. Have to build a work cabinet for the miter saw to get it up to the proper height and raise one of the cabinets I'm going to use as infeed and outfeed tables. Then the miter saw will be ready.
Hopefully I will be able to get the bearings for my table saw tomorrow and get it up and running..
I fired up the lathe and had what at first sounded like a ticking. I checked the pulleys and spindle lock and all were in position. Turns out it was more of once per revolution squeek that went away when the belt warmed up. I guess the belt had a set in it.
Hopefully I can start planning the dust collection in the next few days and maybe make some headway on that.
Re: Shop is really getting set up
Alan Zenreich
Alan Zenreich
It's coming along very nicely
Looks great. Keep the pictures. It will never be this clean again.
josh bowman
John, can we get a better look at those wheels on your powermatic lathe?
Boy you nailed that Barry
They are removable. I jack one end of the lathe up with a hydralic floor jack. Then metal pieces you see on the inside of the wheel support is spaced out enough to form a lip that sits on the underside of the cross beam on the legs. When I lower the jack it sits on this little shelf with the metal and some long lag bolts keeping the wheel in place. I put swiveling wheels on one end and fixed wheels on the other. I picked wheels that were large enough to roll across gravel because when I built this had to roll it across my other driveway to get it in the shop.
the slot in the wheel set is to give access to the hydraulic jack. When I had 400lbs of gravel on the lathe I was still able to move it by myself.
josh bowman
So the metal bars create a kind of cleat that hooks under the leg cross support? Also what's the little square hole for in the middle?
Starting to look like a real shop now John!
Josh the square hole is for the Jack. The legs go under the jack and hook onto the leg cross tie. Then when you lower the jack it simply comes out from that little hole.
It is exciting to see it start to come together. The walls look great. Does she have to beat you with a stick to get you lock it up and come in the house?
Looking good !
