Anyone turning in a yurt?
Jeff Smith
apologize for posting this to multiple forums, but I'm not finding much information on my question. We've recently moved to a semi-remote, small island in the Pacific Northwest. Part of the plan when purchasing our new home was to build a 20 x 24 shop on the property adjacent to the house. Been going through the motions of getting started on construction - there needs to be some significant site prep - retaining wall and fill - to level the site for a post and frame building or stick framing as well. We're locating an engineer to plan and design the site prep. County needs permits for the fill since one corner winds up over 4 feet high. The cost of bringing materials over on the ferry (20 car, open ferry with weight restrictions) starts to ad up.
This weekend we were touring some of the local artist's studios (there's a significant number of artists locally - they hold studio tours on major holidays throughout the year). One studio was in a yurt situated in a somewhat similar situation to my site. It was a pleasant space that seemed to allow for many different configurations. A good conversation with the owner and a little homework online leads me to believe that I can build the platform easily - just a glorified deck, pour a concrete pad for the lathe, and put a 24' yurt on top that will easily withstand both wind and snow loads that we experience locally. Woodstove for heat, double doors both front and back for access, windows all around for light, and fully insulated. And it all fits within budget.
Now the question - anyone turn in a yurt? Know anyone who turns in a yurt? know anyone that has a woodworking shop of any kind in a yurt? Any experience whatsoever with yurts?
Re: Anyone turning in a yurt?
There is one on that Yukon Gold show,
Dick Coers
so they must be pretty energy efficient if they are used in Alaska. Only down side I could see is that if you use a wood floor structure under it, make sure you have plenty of beam under it if you have a big lathe!
Re: There is one on that Yukon Gold show,
Jeff Smith
Dick: I'd better start watching more reality TV - I hadn't seen it...I had planned to pour a cement pad for the lathe itself. All in, the lathe with what I've attached to it is right about half a ton (Robust AB). I like the way it's behaved on a cement slab for the last 3 years, so I though I'd just build a form that goes from the floor joists to the ground, and pour a support for the lathe.
Are you looking at kits or DIY?
Dick Coers
I'm wondering about your climate there. Mainly how much rain? Mildew on a soft structure could be an issue.
Yurts
need not be "soft". The form and framing can easily take hard walls and roof to form the "great room" space with windows and additional wings attached. Google "yurt" and click on the images pages for lots of examples as well as links to plans, etc.
Brad Vietje
Brad Vietje
Jeff,
I've installed off-grid solar power systems in 2 yurts, and 2 issues come up with your electrical wiring:
1) the easiest place to run wires -- really easy -- is below the deck, so you have to protect those wire runs from gnawing critters like porcupines, who can chew through MC or UF wire without a second thought. Plastic conduit is cheap, but oh, so chewy. You'll need rigid conduit -- the threaded kind -- since thin-wall conduit is for indoor use.
2) with an open floor plan, it's tempting to mount outlets in the floors. This could work with the right kind of GFI recepticles, but one solution I saw was to make room partitions to get the outlets and switches up off the floor.
Most modern commercial yurts use a vinyl fabric for the roof & walls, with a wooden lattice material to give stiffness and structure to the walls. These are OK for hanging pictures and such, but not a place for wires, plumbing, or HVAC equipment. Wood stoves have HOT vent pipes, so you'll need a thimble around any penetration for the stove pipe (through the wall, not the roof), so a pellet stove with a smaller and much cooler venting system might work best (even though you'll have all those scraps....) If you are there by day, and gone at night, give some thought to cold air getting in around the spindle, as well as the overall temp's for water or a composting toilet system.
Maybe an outdoor wood furnace or boiler (radiant floor heat) is another option, especially if the deck is elevated. Also, it can be a bit hard to insulate under the deck for water/sewer ins & outs in some places -- YMMV.
Safe spinning,
Brad Vietje
Newbury, VT
Ralph Lindberg
Jeff
On a slab, the worst mistake I, and a friend both made, was not putting a vapor barrier under the slab. Way too much moisture comes up through the slab in the winter.
I would also insulate below the slab (foam sheets/boards) if I had it to do again. Even with the heat set to ~65 in the shop (working temp) in Jan the slab is really cold on my feet.
A friend laid down a bunch of canvas tents on a slab, in unheated storage one winter. All of them were so rotten in the spring I could tear 20oz Duck with my bare hands.
Lyle Jamieson
Lyle Jamieson
If you see Michael Peterson, say HI for me.
