Finish Help! - Spar urethanes
klowwn
Help! In the middle of a project I was using a spray can of Rustoleum Spar Urethane Semi Gloss. After spraying the project with one coat and just starting on the second coat the spray can just stopped spraying. By weight I can tell the spray can is almost half full, but the propellant must have expired.
Locally Menards, Lowes, Home Depot, and Ace Hardware all carry Rustoleum products but none carry the Spray spar urethane.
Can I finish the project spraying with Minwax Helmsman Spar urethane without sanding off the Rustoleum? Or do I need to start over from bare wood?
Thanks
Ricc Havens
Elkhart, IN
