Shift Knob
Ken Cutler
Has anyone turned a shift knob for a floor shift? I was asked to turn one and I have no idea of dimensions for the basic round knob. Any help would be appreciated. Thanks.
Shift Knob
Ken Cutler
Re: Shift Knob
David Walser
Are you asking for the dimensions of the hole in the bottom of the knob with the appropriate thread pitch? I don't recall there being a standard size. Last time I turned one, I had my friend find a threaded insert that matched up with his shifter. I then epoxied the insert into the bottom of the blank and threaded the blank onto a bolt. I mounted the bolt into my chuck's pin jaws and turned the knob.
As for the size of the knob itself, there isn't a standard size. Whatever fits well in the driver's hand is the correct size. Start with the size of billiard ball and go from there.
HTH
2" diameter
Dick Coers
Is what Jegs sells for their classic knob. Make sure you know the thread size for the insert. Lots of options there.
Re: Shift Knob
Janice Manuel
One of the odd jobs I've done was make gear shift knobs for a boat manufacturer..made like 700 of them...these finished about 1 3/4" diameter and had a brass threaded insert. Put those in with a bit of epoxy..These were mahogany, got a dark stain and a urethane finish....
