general seal a cell
joe zarnitz
any problems using this as a stand alone finish on a bowl---tks,joe
general seal a cell
joe zarnitz
Works for me
I like this product a lot. It has many of the properties of my old favorite, Waterlox, but costs half as much. I know that David Marks also uses it extensively in his work. It is self-sealing, so it can be used without preliminary priming or sealing, though I usually dilute the first coat a little with naphtha. I also prefer to wipe on several coats, using just enough to extend it evenly over the surface, leaving a moist slick -- not too dry, not too wet -- sanding very lightly between coats with 320 or 400-grit paper. This approach yields a smooth and relatively dust-free build.
Ellis Walentine, Host
Re: My experience
Steve Criscenzo
I have been using Seal a Cell on bowls for about 4 years and I am very happy with the results. I flood the surface for about 20 minutes and then wipe off the excess. I let it dry for about a week and either buff and wax with Beal system, [semi gloss] or buff with a fine scotch Brite pad [matte finish]. It provides a good seal without a surface build up.
