Mirror question for John Lucas
Dale Gillaspy
John, I am going to make some hand mirrors for my daughter to give to her bridesmaids at her upcoming wedding. Your article in the AW Journal is not available online. I think I have it down OK except for one question. What thickness of wood to you use? I'm thinking that a 3/4" piece to start, then recess for the mirror, but what thickness behind the mirror do you want to end up with to achieve a good balance between weight and durability?
Am I making sense at all? Thanks
Dale
Re: Mirror question for John Lucas
Dale durability isn't an issue. The only durability issue is either breaking the glass or breaking off the handle. I start with 3/4" stock, recess the mirror just a little more than the thickness of the glass. Since you end up turning a bead or other detail on the mirror side you remove a little more wood so a safe recess for the glass is 3/16 to 1/4". Sometimes on really heavy woods I will concave a lot of the center portion behind the glass to remove some weight but you have to be careful doing this because details turned into the face can easily cut into it. I usually reserve this for really nice woods where I don't turn deep details, prefering to use the figure in the wood as my "art".
I have used very thick woods in some instance for special mirrors such as the one that has a box in the top.
I try not to make them too thin because attaching the handle with a strong enough tenon becomes an issue. I use a 3/8" tenon so the wood needs to be at least 1/2" after you turn it. I have on rare occasions drilled and inserted a metal insert into the handle where I needed a thinner tenon or the wood was too brittle.
I also score the wood on the tenon and will sometimes score the wood inside the drilled hole so that the epoxy has something else to grab beside clean wood. Quite often this joint tends to be a cross grain dowel joint which will come apart over the years due to wood movement. Scoring the outside of the tenon ( I just nick it in about 6 or 8 places with the bandsaw holding the tenon at an angle) and then scoring the inside of the hole ( I use a dremel with a course cutter to sort of scratch the inside) provides a sort of plastic dowel inside the regular dowel to keep the handle from falling out.
Dale Gillaspy
Excellent John. Thanks so much. I'm doing 6 by October, with one or two for practice. I remember watching you in Phoenix, but just couldn't remember some of the details. Thanks again!
