THE WOODRAT IS BACK!
Latest project
Latest project
Latest project
clay foster
The knob on the fan control on my truck broke after 12 years. I don't even want to know what a replacement from Toyota would cost, so I turned one out of maple with a little chatter work to dress it up.
Re: Latest project
it's probably a $300 knob
Re: Latest project
But Clay, where is the dot to act as reference?
Re: Latest project
Re: it's probably a $300 knob
clay foster
That's still cheaper than what a Toyota dealer would have charged.
Re: Latest project
Clay I only have one key for my Honda that I bought used. I went to Honda to get a new key because you can't have them made anywhere else. It is $300. I told them they could keep it. The key itself is laser cut and only one place in town can actually do that. The Key Fob which you have to have is only sold by Honda. I can buy a Vale' key for $150 that will at least let me drive the car. Man that's nice of them.
Re: Latest project
That's Cool-or Hot-as needed.;-)
Re: Latest project
John, My son had the same predicament. We found a local locksmith that can cut the key, but did not have the blank. He bought the blank on E-bay (think) and is going to get the local guy to make the key. I think he is getting two for about half of what the dealer wanted. I check out the details if you care and if you think it might help.
Re: Latest project
Re: That's Cool-or Hot-as needed.;-)
walta
So how did you make the “D” shaped hole to fit the shaft?
Walta
Re: Latest project
rd_macgregor
Last time I made a knob, I made the D-shaped hole by first drilling a round hole then half-filling it with an appropriately-sized dowel that I dragged on the sander until half its diameter was gone. It worked fine, except that a wooden knob on a crock pot (my application) has a limited working life; next time I'll use a chunk of plastic of some sort.
Re: Latest project
clay foster
Toyotas have a square shaft. I drilled a round hole in the knob and squared it up with a chisel.
Re: Latest project
Dwight Rutherford
rd, Corian should work well for this.
