bandsaw
bandsaw
bandsaw
Art demers
I'm looking for an after market "quick release" for my Reliant bandsaw anything that fit's Jet Delta or most of the other overseas saw will work I think I've looked allover the net but I'm stumped.Thanks in advance you guy's are great Art
Re: bandsaw
Re: bandsaw
I've seen some plans for homemade versions. (I have a Carter version, that I never use except when I change the blade. I never bother to release the tension otherwise.) Once I saw the homemade version I wondered why I did not think of that and save the money. Unfortunately I can not remember the details or where I saw it.
Re: bandsaw
Re: bandsaw
Chuck Engstrom
Hi Art -- here's a photo of a quick release I made up for my Delta from plans I got out of a newsletter publication some years ago. I can't find my copy of the original, but I will say that I should not get credit for the concept. I've been using this for several years now and it does just fine for me. The original lever shown here failed at the sharp corner to the left of the washer but a replacement with heavier section and a smooth curve next to the threaded rod/washer/nut assembly has held up OK.
The peculiar looking wedge was just a convenient scrap that fit the need. Dimensions are not critical, I'm sure you can work out something appropriate for your Reliant.
Good luck with the project! -- Chuck
