A very generous patron loves to give these enormous salad bowls away. He started with his family, now distant family are asking about them. We started out with an open order to "just keep making them." So when a large log presents itself, he gets more. Last winter he asked for 6 more when I could get to them, and I was then lucky enough to get two large soft maple logs to cut from. It takes a nice log to get these large clear blocks! I'm turning up all the stock that I harvested. Nine so far, two more blocks left in storage to put on the lathe. They are turned to finish in one step, he loves the primitive look of the oval, just as I do. A couple of these 18" diameter bowls are 1 1/2" out of round now. Makes the sanding a challenge, and my hands and wrists are telling me to get these things done!
I couldn't find it in my clips, but some where, I show an articulated arm rest that I made for sanding bowls. First half is a Oneway inside bowl rest. It just sit in the banjo, not tightened down. A couple of U bolts over it hold on a piece or about 3 inch wide plywood. At the end of it, I have about a 3 inch long maple cylinder with a through bolt, and the second arm is on the bottom of it. The plywood has some foam on it for extra padding. Since it pivots, it is easy to rest one hand on it holding the drill, and spin the bowl on the lathe by hand. Since it carries all the weight of the drill, the only fatigue is holding the trigger down. I am on the short high arm for sanding the inside of the bowl, and the lower extended arm for sanding the outside of the bowl. Huge at the end of a long day of sanding. I need to fine a lazy Susan type bearing that is about 3 inch diameter, kind of like the one on castor wheels, but with the mounting plate on both sides rather than wheel and plate..... Having lathe speeds of around 10 to 20 rpm will let you keep the bowl spinning while you sand. Nice bowls.
I would like to see a picture as well, but I do understand the method. Your discussion did get me to thinking about mounting a variable speed cord drill on the outboard side, and through wood pulleys, turn the lathe at 10 rpm or so.
The big deal on sanding these, is to remove the oxidation from the drying process. The small marks and fine tear out is the easy part, the oxidation the HUGE part. Right now I am using a 3" sanding disc on the inside. I hold the bowl on the lathe with a vacuum chuck, and use the arbor lock to steady it. After removing all the oxidation color, I idle the lathe down to about the minimum and blend as much as I can coming up towards the rim. I have to be careful with pressure and speed, or the VFD can cutout. I then switch to a Harbor Freight 5" random orbit sander. It is tall and the nose for the dust bag is quite short, so you can get inside the bowl quite easily. By tipping the sander over slightly, the 5" diameter pad lets me do the transition from the bottom up the side. I only use the 5" random orbit on the outside. First parallel to the rim, then perpendicular. This makes sure I don't sand on any flats.
Doing this many, got me thinking about this factory sanding rig more than once!
Nice, Dick. Its hard to beat a nice big bowl. Try blowing out the free water with compressed air-if the surface appears dry, you will have less of the discoloring. I blow it back and forth until I can't get any more out. I hold a paper towel and blot up the liquid as it comes out.
I finally figured out which clip it was. Around 3 minutes into the clip. I do need to new and improve it, but not having to hold the drill up in the air is huge...
Now, I have to invent or convert some sort of 'perfect' grinder for sanding out bowls. The drills wear out because they are drills and we use them as grinders, and the bearings can't take the side loads. Current thought is to see if they have a higher speed screw gun, which should be able to handle the torque loads, and run a wire from the battery to the drill/driver..... There has to be some thing better.
Any of the lathes with the 3 phase converters can be programmed to run a lot slower than the 50 rpm where most of them turn off now. My PM 3520A would go almost down to zero before turning off. When they upgraded to the B model, PM and the others all went to shutting off at 50 rpm or so. I had Brent English walk me through reprogramming my Beauty so it goes down to 15 to 20 rpm before it turns off. This generally works for most of my warped bowls. With the sanding arm rest, since there is no effort required to hold the drill up in the air, that leaves one hand free to spin the bowl. I have found this to be really handy when sanding as I can see if there are any scratches left from the previous grit, and spend time where I need it.
As for oxidation, for the once turned bowls, which is all I do, I have to start with 80 or 100 grit most of the time. 120 grit some times. Sanding is all about traction, and slower speeds get much better traction/cutting action. Vince Welch started me on this, and the more I use it, the more efficient I have found it to be. If you are sanding at too high speed, you are like a dragster that spins out its tires, lots of smoke, but you are going no where fast. Slow speed drill, with the trigger maybe half way down.
Thanks for the clip. It wasn't what I had imagined, but I really see the advantage. I was Harbor Freight getting cheap brushes today, and was looking at machinery to hack and invent a belt sanding fixture. I have some ideas, but not going to be easy to mock up. That's not stopped me before, but it won't happen soon!
That picture of the belt sander is from the New Holland Bowl mill. On one of the forums, some one posted a picture of an old bowl they had found that had these 'strange vertical scratches' on it. Every one agreed that the scratches came from that type of belt sander. Hard to think around the problem of a rounded 3 dimensional form to sand without it being discs of some sort. I have tried a couple of random orbit sanders, and found out that they work fine with the higher grits, like 220 and above, but almost worthless on the coarser grits. I know Dave Schweitzer of D Way used 5 inch discs on the angle drills. Not sure how fast he goes through drills though. The motors seem to be plenty powerful, but the bearings are not up to snuff. I would like to have the drill mandrill on an articulated head and have all the weight on the robo arm, and a speed dial off the lathe some where. A flex shaft would work, but it needs maintenance. Probably a 1/2 to 1 hp motor too. Still trying to figure it out....
