ADVERTISE HERE - FREE TRIAL
Vacuum Pump Question - New one I am Sure!
jake Niedling
I bought a Gast 0523 vacuum pump from a another turner who has not been able to turn and use it for a couple of years now. It was in good condition and operational the last time it was used some time ago.
Well, when I hooked it up and turned it on, it sounded good. When I started closing the vent, I got up to around 18 "Hg, when the pump motor started shutting down and sounding like a gas powered lawn trimmer that won't start when you pull the cord. After a few minutes, I can start it up and it sounds good again, but will eventually do the same thing. The motor I think is getting hot and suspect that the motor thermal protection is kicking in. I have checked all the hoses, filters and there is no problem from a hook-up perspective. I haven't put a meter on the motor yet to see what the current is doing. So I sure could use some input (wisdom) on this problem. Appreciate any comments.
Re: Vacuum Pump Question - New one I am Sure!
Probably has stuck vanes  *LINK*
owners manual
it hasn't been used in a long time
I don't know what would cause that but Dick is probably right. I know it hasn't been used in years.
jerry bennett
Hi Jake,
Contact Gast at www.gastmfg.com. For the 523 series you will need a rebuild kit no k 478. Their tech guy will get you going. They also have a video on how to do it.
Jerry
Problem Solved
jake Niedling
Since I am a mechanical engineer, I have always said that problems are always electrical until proven otherwise. :) Well I did call the GAST MFG technical service department and they were great to work with at trying to solve my problem. He felt it was an electrical problem and offer several options. One was whether it was wired properly because it was acting like 110v connected to a 220v motor. It is 220v with 3 wires. I had an electrican wire up a new plug for the motor and he had one of the hot leads on the wrong post. I moved it and the unit is running just fine now. Got a vacuum of about 22" Hg and the motor is staying cool. A happy camper now. Just need to get it all mounted . Thanks for the recommendations.
Dennis in Southern Oregon
Re: Problem Solved
Hey as an electrical engineer, I take umbrage with that remark. It WAS a mechanical problem; a wire was connected to the wrong screw!
