Is there any particular reason for NOT turning a fairly large Celtic knot -- say in a hollow vessel from a cube about 12 inches on a side -- in wet wood? I'm a little worried about turning something large and heavy, considering that it has a bunch of man-made "cracks" in it. What's the best glue for something like that?
Ditto Your going to have wood movement in all kinds of directions with a celtic knot glue it, unless somehow you oriented the grain all the same. Still I doubt it would hold up for very many years if in fact it lasted for months.
Wet wood to wet wood I would use a Polyuethane glue such as Gorilla glue. But bear in mind that it is not a gap filling glue (even though they say that in one of their commercials). Any gaps will turn into foam which isn't even remotely strong.
If you turn a large green bowl or closed form vessel green, and carve it, there shouldn't be any checks if you get it down thin enough, then dry it slowly.
Carving green wood is a dream compared to dry. It is typically about half as hard as when dry.
I think he was asking about using the glue up method with contrasting wood since he asked about glue. However the best way to do this in green wood is to burn the celtic knot in the way sharon Doughtie does.
Some of these responses apparently missed what I was trying to do. You do understand. The essence of my question has to do with getting a Celtic knot into a hollow form, which, as far as I know, involves glueing four slices into the wood, and still being able to turn wet wood , which is so much easier. The basic problem is dealing with a glue up ,on the one hand, and using wet wood on the other hand. I suspected that these issues were more or less at odds with each other. I believe after reading most of these responses that I had better stick to dry wood for a Celtic knot . I will check out the burning method you mentioned. That seems interesting.
The question was not about deciding on using dry wood vs a glue up. The Celtic knot ( except for this new idea about burning in the next post, which I plan to look into) REQUIRES a glue up.
