Re: Best gouge for back-hollowing cut? (end grain)
mo'wood
I use a common ⅜" spindle gouge with a swept back grind, though larger sizes will work too.
A few details that may help you avoid exceptionaly memorable catches when doing the back-hollowing cut are:
1. The gouge flute is rolled over to the right, and the path of the cutting edge (left wing of the gouge) is nearly straight up to 12 o'clock in relation to center, while the handle stays on the left side of the axis of rotation while dropping down.
2.The cut is started just inside the edge of the opening, so that the back of the gouge rubs the edge of the opening.
This was the key for me to become comfortable with this cut: you use the surface of the interior and the edge of the opening to lever the tool up into the interior, while still keeping contact with that tool rest, which can't be set too low or too high. The cut starts at center, but the bevel rubs a lone that is nearly vertical, while the cutting edge works between 12 and 2 o'clock. There must be room to drop the handle without striking the lathe bed, and forward pressure must be maintained to keep the bevel on the wood.
It works best with a grind that isn't too steep- a slightly rounded left bevel helps too. And lots of practice. And a sense of humor. And catch-proof wood.
Good luck!
