craftsman 15" lathe parts availability
My new neighbor is selling a practically new 15" craftsman variable speed lathe. Before I send this out to my friends I would like to know if parts are available. I looked online and had little success although I did find one place that had some parts listed but not many. The price is right but if you can't get parts then it could end up being a boat anchor pretty quickly.
Re: craftsman 15" lathe parts availability
Lyle Jamieson
Lyle Jamieson
Parts or not, I have heard some bad news about that lathe. Not a good buy at any price.
Lyle I've heard both good and bad news. Some love it and some hate it. The one we used for our club for a while was an absolute dog but it had also sat in a garage and had rusted ways and who knows what else was bad by then.
Dennis in Southern Oregon
I don't know about that particular lathe, but Sears has parts for an amazing array of past products. I suggest a Google search for Sears Craftsman parts. It will help if you have a model number.
Dennis
Roger Chandler
John.......my first lathe was a 15" Craftsman VS lathe. It was driven mechanically by a gear shaft in the headstock and not by a belt......some of those do have belt drives.....They were all made by Palmgren for Sears.
Mine broke that gear shaft and I tried for over 6 months to find a replacement, even went so far as to contact 3 different machine shops to make one, but it required a special hobbing machine to make it, and the place that did have that machinery wanted $900 to make a part for a $600 lathe! I could not find that part through Sears, Palmgren, or any other entity.......went online and tried to find a used one for parts......all to no avail.
Ended up taking it to a scrap metal yard and junked it! Would I recommend....no way!
hu lowery
Sears and the original manufacturer both like to pretend these lathes never existed. Parts supply is largely nonexistent. If it is the belt driven Reeves drive version the belts can be found from third parties. Parts beyond that don't exist apparently. There are an amazing number of these lathes in like new condition out there, mainly because people discover they have purchased the world's largest pen and bottle stopper lathe. Anything larger than that challenges these machines.
I will be trying to move one shortly. It is on a one off screwed and glued wooden stand that has a slanted shelf to hold thirteen 35 pound concrete half pads. The plan is to sell the stand and tell whomever comes for it that they have to haul off the lathe too since it is bolted to it.
The lathe has actually been running most of the time after having to take it apart a half dozen times to free the Reeves drive. Apparently I have sanded a little running clearance in there. I use colloidal graphite to lubricate the Reeves drive assembly. The spring is about eight feet long or slightly less and without a home made compresser which is admittedly simple to make it is a life threatening maneuver to assemble or disassemble the upper shaft assembly.
There is no stop at maximum RPM. If you turn past 2000 RPM the primary drive belt serves as the stop. Burning rubber is the first indication there is a problem.
This lathe was quite a learning experience. The too high lower RPM and too low upper RPM make things a treat too. All in all if this lathe can't persuade someone to give up wood turning they are either amazingly persistent or in need of being bored for the simples.
Hu
someone with my repair skills needed
sounds like he shouldn't sell this to anyone who can't repair anything that moves. When I've posted questions on this before I always get a few people who swear by them and love their machine. Most interesting
I swear by mine all the time!
hu lowery
John,
I swear by mine all the time. Of course I mean in near proximity to it! Yet another gotcha is the rated horsepower. It is like the Sears 24HP vacuum cleaners, grossly exaggerated. I'm so in the habit of hand cranking, grabbing the piece and giving it a spin as I hit the power switch, I'll be lucky if I don't injure a hand when I get a machine that can turn over a tea cup all by itself!
Of course I have slightly exaggerated the flaws of the machine. Truth is, I finally have gotten used to working with it and don't have that much trouble with it these days. Got to check every day before I start turning that the Reeves drive split pulleys haven't stuck and I'm not burning up that sixty dollar belt. The Reeves drive belt is stout enough it probably would transfer 25-50HP. The primary belt is more revealing of the machine's power, it was sixteen or twenty-six dollars and looks like it came off a sewing machine.
These machines hate sitting up. After learning how to keep it happy I do think it would work pretty good in a climate controlled shop if it was ran at least a couple three times a week. Need to start it and run the Reeves drive all the way up and down every few days and it isn't nearly as inclined to stick. Need the spring compresser on hand though, it will still stick. I probably have tearing the Reeves drive down, freeing everything, and lubing everything down to about an hour now when things work pretty well. I have had to use tapered rock maple square stock to free the cast iron half sheaves, that is pretty scary knowing the machine is pretty much scrap if you break one.
I will offer the machine for sale, with full disclosure. Despite the 15" swing and I think 36" or 40" distance between centers this machine of mine is happiest with six or seven pounds or less on it, less than 12" diameter. I have pushed it to it's limits turning bowls, and it pushed me to my limits too. A friend has a 50BMG chambered rifle and there is a genuine temptation to put it in the back field and make chunks fly. Figure a lost chunk of cast iron would ruin a tractor tire as a final piece of revenge and under the right circumstances the lathe works fairly well for light use. If I wasn't cramped for room I might keep it as a sanding and finishing lathe.
Hu
I shot my old computet and my boss's old iphone
John lucas
That was a fun day by the way an iphone wont stop a 30-06 or even a 22lr
Did Siri bleed?
