Bandsaw maintenance
Bandsaw maintenance
Bandsaw maintenance
Philip Duffy
Well, my nice long posting this morning about how to check your BS for problems was too long or too obnoxious so Ellis decided that it should not be posted. So, here is a shorter version; check the torque on your attachment bolt for the riser block, make sure your drive wheel is securely attached to the shaft, if the tires are worn get new ones but in the mean time glue them in place with contact cement. The end. Phiiip
Re: Bandsaw maintenance
jim breeden
Are you trying to tell us something, as my bolts are always torqued. :b
Riser blocks can often be a source.......
JamieDonaldson
....for alignment errors between the wheels. And they can also induce body frame flexing, especially when changing blade sizes and tensions.
