band saw blade jumps off the lower tire
Philip Duffy
Need some advise before spending unnecessary cash. Changed the blade 2 days ago and did not do any sawing after the change. But today, a few simple cuts resulted in the blade backing off the bottom wheel (Jet 14in with riser block). Several attempts to adjust the blade track and tension resulted in the same loss of the blade. Bottom wheel seems to be tight on the shaft. Is it the tires?? They are about 4 yrs old. All advise appreciated. Philip
