X-Mas Tree Ornaments -- Variations
Brad Vietje
Here are 2 variations to the little tree ornaments I posted a few months back. There are darker woods, turned to a conic shape, then painted white (cheap-o spray paint only for now, but brush-on would cover better), then cutting through the paint on 3 axes.
Since there is no going back to clean up any chipping with a skew after the V-cuts, these require going in there with a little confidence and going for clean results.
Apologies for the awful flash-on-camera photos -- no photo booth at the moment.
Butternut:
And then Walnut:
The Butternut one was not sanded, and could use more paint. I suspect brush-on would cover a lot better. The Walnut one was sanded with 220 and 320, so it has a smoother surface. Used spindle gouge and skew for the Butternut V-cuts, and tried a flat-bevel skew for the Walnut one.
No big deal, but a fun little project to give away when the holidays roll around. For darker woods like Walnut or Mesquite, might be nice to try silver or gold paint as well. These are solid wood, and can stand as seen here, or hang from a little applied wire loop glued into a tiny hole at the top.
Safe spinning,
Brad Vietje
Newbury, VT
